Is this explained in the Aeroforce manual?cloud9 said:I use my Aeroforce gauge to pull and clear the codes.
I'm not sure, but it's pretty straightforward. Push both buttons to bring up the menu. Then scroll down (left button?) until you get to "GET DTCs", then hit the right button to select. It will either display the resident codes or say "No faults". When you get back to the menu you can then scroll down to "CLEAR DTCs" and hit the right button to select and clear them.5 DOT 0 said:Is this explained in the Aeroforce manual?cloud9 said:I use my Aeroforce gauge to pull and clear the codes.
CaliMR said:So basically they just cleared all the codes using a scan tool? Or was it something different? Can a battery pull clear them?
I received my Cobra Jet grille this past week but I'm not ready to recommend it yet. I'm waiting to hear back from FR on an issue I have with it. I'll post more later in the grille thread.boss1 said:Ok well dropped the car off this am.... All I know is that I cant wait to get back to the track..... Next event: Chin Motorsports VIR March 3-4. Ordering the trans scoop and brake duct kit today. Any consenses on the front grill solution short of $375 for the S grille? Thanks.
You can just pull it on warm track days if you're starting to run hot. It takes an 8mm socket, a flat screwdriver to pop the 8 push pins and release the side tabs on the grille and about 10 minutes time. CHT/ECT will drop 20-30 degrees just like that.boss1 said:Ok well dropped the car off this am.... All I know is that I cant wait to get back to the track..... Next event: Chin Motorsports VIR March 3-4. Ordering the trans scoop and brake duct kit today. Any consenses on the front grill solution short of $375 for the S grille? Thanks.
Here's a pic of JScheier's grille he made out of a GT grille surround and chicken wire. It did the trick in lowering his coolant temps.boss1 said:That sounds great but what about radiator damage from flying rubber ect? Someone needs to make a screen kit for these....Please.....
adam81 said:boss1 said:Ok well dropped the car off this am.... All I know is that I cant wait to get back to the track..... Next event: Chin Motorsports VIR March 3-4. Ordering the trans scoop and brake duct kit today. Any consenses on the front grill solution short of $375 for the S grille? Thanks.
Go to latemodelrestoration.com and get the S grille for $309....
Remove the grille for track days, takes about 10 minutes. There is a write up somewhere.
Great call on the brake ducts and trans scoop. The trans scoop is good for like 20 deg or so! Make sure you remove the rear dust shields and little mud guard thing if the front rear wheel well.
By the way do you know a guy with the last name Culpepper?
Yes Dave is a very good friend of mine. I am probably the one that got him started on the 302S.
I would say the LS wing since they were designed to work together as a package.boss1 said:Ok so I have the front LS splitter now for my car. What is the best wing to run? I assume the LS since it has been tested over and over but thought I would ask before I purchase. I do not plan on running the tiger hood yet. That will be a next year item if I decide to do it.
Also are there any options for tow hooks if I don't want to drill the bumpers?
How about tie down hooks underneath? I have not had mine up on lift to check it out yet. Right now I am looping through the wheels to trailer with straps but I prefer latching underneath.
Lastly, is anyone running a rear axle resovior as opposed to the turkey baster ford fix?
Thanks, T.Roy
Are you going straight backward and forward with the through the wheels method? I was planning on tying it down that way and it's how Mac's showed them on their website too. I got their Pro Pack through the wheel kit for my new trailer. I just hope the car won't bounce side to side at all but since it's ratcheted down firmly I guess it shouldn't.boss1 said:Yes through the wheels works fine. I always feel like I am messing with the alignment with the front straps crossed....
cloud9 said:Are you going straight backward and forward with the through the wheels method? I was planning on tying it down that way and it's how Mac's showed them on their website too. I got their Pro Pack through the wheel kit for my new trailer. I just hope the car won't bounce side to side at all but since it's ratcheted down firmly I guess it shouldn't.boss1 said:Yes through the wheels works fine. I always feel like I am messing with the alignment with the front straps crossed....
