- 71
- 0
Ok call me old I am, call me old school I am. I find the lopey idle stupid. With track key is there a way to turn it off.
You must be talking about dopey idle. ;D If my other car had that rough of an idle I'd take it to the dealer and make them fix it. I'm ok with the idle but what I like better is how the car sounds on accel and decel with TK.emcrace said:Ok call me old I am, call me old school I am. I find the lopey idle stupid. With track key is there a way to turn it off.
wish I could get the JLP lopey idle with AED performancefour-walling said:Wow, what a turnabout for poor, ole, lopey idle.
First folks complained they couldn't get it.
Then folks complained it wasn't lopey enough.
Now any lopey, is too much lopey.
It has finally been kicked to the curb and may the feature rest in peace.
Justin said:lol am I the only one that reads the TK directions?
LOPEY IDLE DISABLE:
To request all of the TracKey functionality without ever entering lopey idle mode, hold
down the "OFF" button on the left side of the steering wheel while starting the engine,
and continue to hold it down for at least 5 seconds after the engine starts running. The
tachometer will sweep to 9000 rpm indicating that lopey idle disable mode has been
requested. This will prevent lopey idle mode from enabling until the next time the
engine is started.
[pdf]http://www.trackey.ford.com/trackey/include/TracKey_Customer_Instructions_V1.2.pdf[/pdf]
emcrace said:. The lopey idle gives mixed signals that an old school tuner builder like myself does not want. Soory guys.
emcrace said:Thanks Justin will do. I have spent a life time getting my performance and racing machines tuned to as close to pefection as possible. For example my full race Lotus Super 7 was a beast. It also hunted and bagged many Porshe's with only a 1600cc push rod motor. An I mean full race, sanctioned events. That car tuned properly with Webers half the size of the motor still idled smoothly at 700. To intermitantly just turn an injector off to poorly simulate a radical cam is childish. It does not sound even a little bit like the real Mcoy. Besides the sillyness after runing the Boss hard or missing a shift I can listen to a motor and get a very good reading of it's health. The lopey idle gives mixed signals that an old school tuner builder like myself does not want. Soory guys.
emcrace said:Sorry you seem to be reading a different post than mine. I have never slammed track key. I really admire Ford for it. You already know I am old sonny do you know what an scope is? Mine shows random short duration injector pulse just after idle stability. Sniffer in tail pipe does not detect rise in nox or hydrocarbons. Sorry check your facts you are wrong.
dabossinne said:I think everyone agrees that the lopey idle feature of TK is not so "lopey" as it is, um, "shaky" (jittery?). But, a gimmick? i would argue "no."
First of all, the lopiness, minimal as it is, is not produced by intermittently shutting off an injector. It's produced by the Ti-VCT cam phasing changing the timing between the intake and exhaust cams in each cylinder head to produce more overlap. The same thing you'd do on a on old-school cam-in-block OHV V8 by swapping to a "bigger" than stock cam, TK does with software. I am guessing that -- and this is just an educated (i.e., butt dyno) guess without knowing the actual valve event numbers in TK vs regular key -- that the TK software changes cam timing not only at idle, but also to enhance low and mid-range power.
The idle parameters are limited by what they can get away with regarding emissions compliance, and if you'll recall, Ford Racing was late in coming out with TK in 2011 because they had problems getting it CARB certified in CA, ostensibly due to idle and low RPM / cold start issues. This is probably why the "lopiness" is somewhat disappointing, and why they have programmed in the TK engine warm-up parameters before the lopey idle function kicks in.
Also, TK software is adaptive to, or "learns" your driving habits. If all you do is drive around on the street and at mostly low speeds you'll find over time that TK idle smooths out. If you go to the track, though, and really run the car hard for a period of time (no idea what the temporal parameters are w/in the TK adaptive algorithms), some of the "lost" idle lopiness will return.
So, I say cut Ford Racing some slack and be grateful they even attempted to program in a little lopiness at idle, not to mention TK overall. It's not a gimmick; it a factory "tune" that is unique in the current automotive world, and does actually improve the car's performance feel and expand its performance envelope. That's no gimmick.
