- 30
- 1
Hey all. No matter if I use the red or grey remote to unlock the driver's door, 90% of the time I have to pull the handle twice to open the door. Any one else experience this? Any fix I can do w/o taking it back to the dealer? Thanks.
leland302 said:Hey all. No matter if I use the red or grey remote to unlock the driver's door, 90% of the time I have to pull the handle twice to open the door. Any one else experience this? Any fix I can do w/o taking it back to the dealer? Thanks.
orng302 said:I have this same issue on my 2013 F-150. It is intermittent on mine.
I had the same problem after I disconnected the battery. Try this: with the car door closed turn ignition on but don't start the car. Run the window all the way down, then run the window all the wAy up. Repeat. Turn ignition off then exit the car. Window should now drop upon opening. This worked for me.leland302 said:TMSBoss: No, the window does not drop slightly on the first pull.
