Polaristxguy said:M2Cents! My motorcraft died after 2 1/2 years. I replaced it with a Red Top Optima and now on my 3rd one. The first two lasted about 12 months each with both of them loosing a cell. In all fairness I'm not sure it's all the batteries fault. I have a .2 volt parasitic draw that I can't track down, unit I do keep the car on a tender.
TMSBOSS said:I have had similar issues with my car. Battery is dead after being left sitting.
Is this a battery issue?
With the battery returning quickly after a recharge, I don't think so.
Putting a more expensive light weight or jel battery will change little if the root cause is not found.
I know what causes my issue. A GPS transmitter and a OBDII transmitter along with standard anti-theft devices and the slight power draw from onboard computers are the likely cause.
I have never had an issue When I remember to plug in the battery tender. Had I once checked the fluid level in the original Boss battery, I may have gotten more than the 5 years I did from the OEM battery.
byronj said:The battery doesn't return after jumping the car. It's dead. I'm sure my ain't theft device and other gadgets help the draw but the car does not sit that long at all.
Bought it! I have constantly had dying batteries since the car was new. Battery tender, here we go!CA302LS said:Byron,
I'm 4 years on my factory battery and it still tests new, but I plug in the tender each time I return to the garage.
It's really easy with the pig-tail kit https://www.amazon.com/Battery-Tender-021-0123-Junior-Charger/dp/B000CITK8S
Jim
302 Hi Pro said:Yesterday afternoon while inspecting the engine compartment and fluid levels, I noticed my negative battery terminal was loaded with crud.
I suspect my battery has a hair-line crack near the negative terminal, or has began to vent excessively for some reason.
Scheduled maintenance service next week, and I'll inspect and test then will replace. My Boss production date is the 3rd week of November 2011 and the battery is just over 5 years old. It's due for replacement.
I like Optima batteries and have had good results with them in the past, but I'm leaning towards MotorCraft to keep the Boss OEM, (visually).
Always something to do.
302 Hi Pro
byronj said:Got the new battery installed under warranty. Now it's time to drive.
302 Hi Pro
superhero said:I'm in the same boat as you. I think my car was built 4/2011. Will replace with stock battery. Had good luck with it and like you say keeps the OEM look.
Any idea what a stock battery cost?
