Watson Racing Roll Bar for 2015+ S550 Mustang and GT350
Discussion in 'Suspension and Chassis' started by VoodooBoss, Feb 24, 2015.
  1. VoodooBoss
    VoodooBoss Rick Moderator
    20,166
    2,593
    Nov 30, 2010
    Just in time for those of you ordering GT350's.
    http://shop.watsonracing.com/2015-Mustang-S550-4-Point-Roll-Bar-p/wr-15-boltincage.htm
    [​IMG]
  2. C7 B8
    C7 B8 TMO Advanced
    124
    21
    Nov 13, 2015
    Re: Watson Racing Roll Bar for 2015+ Mustang and GT350
    Can we get enough interest to get another Group Buy going? Im in.
  3. VoodooBoss
    20,166
    2,593
    Nov 30, 2010
    I'm working on it but it won't happen until early next year.
  4. C7 B8
    C7 B8 TMO Advanced
    124
    21
    Nov 13, 2015
    Fine by me since tracks in the NW are wet until April/May :) Im interested in a package deal with the backseat delete kit.
  5. VoodooBoss
    20,166
    2,593
    Nov 30, 2010
    And photos from Black Boss's WR roll bar install. One of the first in a GT350R.
    Rear mounting plates are substantial:
    [​IMG]
    They mount to a reinforced portion of the rear floor pan -- note factory spot welds to the right:
    [​IMG]
    Minor trimming of the rear trim panel and RSD panel was required for the main hoop:
    [​IMG]
    And obviously holes are required in the RSD panel for the rear supports:
    [​IMG]
  6. Black Boss
    Black Boss TMO Addict
    1,643
    1,195
    Sep 29, 2012
    Michigan
    One more note on the install:
    https://trackmustangsonline.com/index.php?topic=10457.msg152188#msg152188
  7. cloud9
    cloud9 Gary
    6,581
    7
    Nov 29, 2010
    Sioux Falls, SD
    Looks great 8) Now that they've finished yours, they're finalizing the installation instructions so I can tear into mine!
    [​IMG]
  8. krt22
    krt22 TMO Advanced
    179
    Jan 4, 2016
    Cloud9, are you going to get the watson rear seat delete or just leave the passage open?
  9. VoodooBoss
    20,166
    2,593
    Nov 30, 2010
    @cloud9 what did the UPS man bring you today? ;D
  10. cloud9
    cloud9 Gary
    6,581
    7
    Nov 29, 2010
    Sioux Falls, SD
    Two brown boxes ;D I haven't opened it up yet. My shipping manager just commented about how light the boxes were and I just said GOOD! Waiting for the install instructions for the bar so I can get started.
  11. cloud9
    cloud9 Gary
    6,581
    7
    Nov 29, 2010
    Sioux Falls, SD
    Sorry, the answer is yes, it just arrived. Talking to Patrick it sounds like the leading edge where the edge of the seats would be is fastened with Velcro instead of bolts on the S550. He said it's just too difficult to drill that part of the chassis with this hardened steel they are using. It will be fine though since that's the way the kit I had on the Boss worked.
  12. Cobra Guy
    Cobra Guy TMO Beginner
    5
    Nov 28, 2015
    Hey Cloud 9,
    Have you installed your Watson Roll Bar yet? I have installed mine but I have not cut the holes in my RSD for the back bars that attach in the trunk. I am a little nervous about cutting these holes without a little more guidance. I got the Ford OEM RSD and it was expensive and don't want to screw it up. I am trying to figure a way to transfer the line of the bars onto the RSD.
  13. cloud9
    cloud9 Gary
    6,581
    7
    Nov 29, 2010
    Sioux Falls, SD
    No, unfortunately I'm still waiting for them to send the install instructions. Did you get instructions for the S550 and just go off of those? Patrick said the delay is incorporating the instructions for the RSD.....which I DO NOT need since I bought Watson's RSD kit. I emailed him again today about getting the instructions so I can get going. Patience is starting to wear out........
  14. SCGT500
    SCGT500 TMO Advanced
    133
    6
    Jan 16, 2016
    Do these bars have any certification? Are they regular steel or chromoly?
    I like the RPM bars, although a little more expensive they are certified and 1/2 the weight in chromoly.
    I have a 6 point bar coming and it weighs in between 37 - 39 lbs. custom painted to match or powder coated.
  15. VoodooBoss
    20,166
    2,593
    Nov 30, 2010
    I don't see a S550 roll bar on the RPM website. The WR bar was designed with Ford Engineers to make sure attachment points are in the strongest possible locations. WR makes Ford's Cobra Jet and Boss 302S and GT350R-S race cars so I'm pretty comfortable with their design. They use TIG-welded 1.75”x.120”-wall DOM tubing. I like the idea of a lighter bar if it provides the same or better margin of safety. ;D
  16. SCGT500
    133
    6
    Jan 16, 2016
    Its a certified bar, meaning it is up to standard for most track rulings. They have the S550 bars and are working on adding them to the site. I understand they have a GT350 in their shop right now to fit/tweak, and also available. I'm sure both bars are great, I just like to save weight wherever I can...makes up a bit for where I'm slow in other areas. LOL
    I'll post more once it gets here. :)
  17. C7 B8
    C7 B8 TMO Advanced
    124
    21
    Nov 13, 2015
    Watson for me all the way. For reasons VoodooBoss sited.
  18. cloud9
    cloud9 Gary
    6,581
    7
    Nov 29, 2010
    Sioux Falls, SD
    A friend of mine suggested the following. It's what he did on his car a few years ago.......
    "A good way to make the holes perfect is to get a cardboard tube the same diameter as the down tube. Then you can match the angle needed and cut the pattern to butt up against the RSD and mark the holes for cutting. My holes were a weird shape due to the odd angle but if you remember they fit perfectly around the tube."
  19. Cobra Guy
    5
    Nov 28, 2015
    That's a good idea. Patrick used a piece of pvc pipe. I tried this but the inside diameter of the pipe was too large. Tried wrapping tape around the nubs on the main loop but still too much play for me to feel I was getting a good line. I will try the cardboard tube which I just happen to have from Christmas wrapping paper. Thanks
    PM me if you want me to walk you through the roll bar install.
  20. cloud9
    cloud9 Gary
    6,581
    7
    Nov 29, 2010
    Sioux Falls, SD
    Patrick sent me the install instructions and they are great. Very detailed with lots of photos. It looks pretty straightforward and I'm going to get started this weekend. I'll also test fit Mike's sub-belt bracket for those of you waiting on that.
Share This Page
