Black Boss said:For the Lap Belts I used the Cooltech harness mounts bolted to the rear seat track bolts:
For the sub belts, I drilled through the floorpan and used eyebolts:
Here's the view from underneath:
The LH bolt is very close to the Fuel pipe -- be sure to drill from underneath:
I used the Planted Seat base, Recaro sliders and Sparco side mounts. Had to drill a couple of holes to match the sliders to the base, but not an issue. I may eliminate the sliders once I've fine tuned the setup.
Used the nuts welded to the plates that came with the Schroth belts for the sub belts and applied silicon sealant to the plate prior to torqueing the eyebolts.
neema said:Thanks for the great response! The eyebolt plate for the sub mount came with your harnesses?
They look really nice. still hard to see on my car due to the roush side splitters. The sound is much louder then stock. I have 3/4" plates in and its still crazy loud. I may choke it down to 1/2".The Rip said:Justin, how do those Kooks pipes look and sound?
I really would like to add these to my car.
Justin said:They look really nice. still hard to see on my car due to the roush side splitters. The sound is much louder then stock. I have 3/4" plates in and its still crazy loud. I may choke it down to 1/2".
Now you get 0 directions for installing these. took me a little bit to get them on. the pass side is contacting somewhere makes a racket above 3k I will put in the spacer they sent along to see if that gets it far enough away from the pinch weld back there. I had clearance issues with the stock pipe had to shim it up to keep it from hitting as well. so it may just be my car.
After the winter lets up I am going to pull the tips off and polish them to a high luster.
If you have cat deletes on your car you may need to wear ear muffs to drive the car with these on.
I have an ARH off road x pipe with side pipe hook ups. with those you cant use cut outs with the stock side pipes. so with the kooks you cant either. Hopefully that helps.GottaBoss said:Justin, just to confirm. Are you using the Kooks side pipes with the stock exhaust H-pipe? If so, can you confirm that you used the (approx. 3/4") spacer as well as the gaskets and restrictor plate when connecting them?
I'm planning to buy a set but want to make sure I can use my electric dump valves (which take the place of the spacer) with them.
Thanks
Justin said:I have an ARH off road x pipe with side pipe hook ups. with those you cant use cut outs with the stock side pipes. so with the kooks you cant either. Hopefully that helps.
