Aggressor custom splitters for sale now.
Sam,
Mine arrived yesterday and looks great!
My bracket comes in tomorrow, and I should have it all buttoned up that afternoon if UPS gets here early enough.
I did bolt it up, and I think I need to have the bumper unhooked to get the last two outer bolts in. And I might slot a couple of the holes in the center/back for ease of installation and use the original bolts/washers.
Thanks!
Grant 302 said:
Sam,
Thanks!
Thats Awesome Please post pics for everyone once you are all set Let me know if you have any trouble or questions happy to help.
thanks
Grant 302 said:
Sam,
which version did you go with....Street or Race?
I ordered the street and its still in transit. hopefully it will arrive by this weekend.
Please post some pictures so I can see what I have to look foward to... ;)
Thanks!
Thanks!
As requested! Here are a few:
I couldn't get the outer two bolts to line-up even with the bumper unhooked. So I took everything apart to check where the holes would line up 'naturally' with just the facia sitting on the splitter. I was able to put bolts in all the holes except for 6, 3 each side, inboard of the outer holes.
Passenger side marked:
Driver side marked:
Driver side drilled:17620304765_251269e5e8_z.jpg
Passenger side drilled:
Facia bolted to splitter top side:
Under side view. I used the oem bolts and washers in the siamesed holes:
DONE!
Driver side marked:
DONE!
Ok thx for the update from the pics looks like those 3 holes need to be moved up and out maybe another 1/2" other then the miss aligned wholes is there any other fitment issues please let me know so I can adjust the next splitters.
Thanks again.
Just to be clear for everyone else, I'm perfectly happy with the splitter! I knew that as a prototype, that some drilling or tweaking might be needed.
I didn't take measurements, but I think they are all less than 1/2" out and are mostly outward. The 'front' one is siamesed with the existing hole so that's just less than 1/4" and the other two are maybe 3/8" out and only slightly forward. I used a 1/4" bit since I was using my facia as a template. Looks like you're using a 5/16" so there should be a bit of wiggle room.
Thanks again Sam!
Thanks again Sam!
Much appreciated bud. I will do my best to make the adjustments make sure it's correct.
I was told Mine arrived yesterday late afternoon. Didnt even have time to look at it. Hopefully this week end I'll have some time.
Grant, I sure do like the look and the added touches....BOSS 302
How much bigger is it from the WC splitter. It looks like it bigger than the WC but smaller than the LS.
Looking for someone that's interested in testing a prototype rear diffuser kit.. DM for more info
TymeSlayer said:
I am interested in getting either the WC or LS version for my 2012 - with the Boss 302 engraving and the stanchion hardware.
hey bud messaged you back.
thansks
THRAPY said:
Just got my fender spats last night. Do you have any closeup pics of how it's aligned and mounted?
Whats up bud, as for the rear diffuser no I can ship it as long as you can post pics and let me know any changes or improvements that are needed.
it will require some modifications and cutting of your lower rear valance on your end to get it to properly fit.
I will post pics later of it assembled with pricing.
Happy you got the wheel arches as for placement its really up to you but I will shoot you some pics of mine later tonight
Its best to align the bottom with your current splitter this will basically denote the top location. The plastic is easy to bend, place in the sun and use your leg as a bender to pre-form to the wheel arch this helps a lot for getting it into place.
DM me if you have any issues.
thanks
Didn't measure it, but that's my impression too.
