- Thread starter
- #61
You are sure your banging is from Coil Bind ? Because I have coil bind on my rear Ohlins springs since initial install. But there is no banging.
Yes. My photos show it clearly.
Your photos show clearly the coil bind but how you are sure the banging is from the coil bind and not from something else ?Yes. My photos show it clearly.
I've run vorshlag plates with steeda oem style springs, on mag ride struts. No banging noises. Occasional clunk from the sphericals. All barrel style springs and even coilovers will have some bind on the first couple of turns. That might click but should not bang as there is still compression available in the 'free' part of the coils. I do suspect endlinks, clearances are tight with all brands. It may be worth removing them and going for a short drive?
Caster camper plates?According to BMR's website the 83 is the front and rear spring set, 84 is the front only springs and then 85 is the rear only springs.
I bought the same Springs as you around the same time but I bought mine from American Muscle. I also have the BMR Caster camper plates but I don't experience what you have going on at the moment. I hope you get it sorted.
Okay I was using text to speech and failed to see that even though I edited twice but I do like the AI generated pictureCaster camper plates?
OOOOOHH NO my friend. I'm sorry to report. This picture is REAL. LOLOkay I was using text to speech and failed to see that even though I edited twice but I do like the AI generated picture
Any word back yet?Have not done that, but have inspected and retorqued several times. There has been no indication of them being loose or impacting any other parts of the suspension system.
I appreciated everyone’s input so far and look forward to anything else that is offered.
