S550 : rear brake upgrade, ran the numbers and got a surprise
3MIN READ​
I did a long research on every possible option from hardware prospective to find out if the solution might be the OEM system with better ABS. please bare with me 3minutes.
Where I'm at: 2018+ S550 Performance Pack, moving to sustain 40min NASA ST2, 30–40 min races. car is extremely fast but Ive done only TT with it .
Fronts are the factory 6-piston Brembo, 380x34, running CSG C1 pads
Rear is the OEM single-piston floating caliper, but on a 14" (355.6mm) x 28mm 2-piece rotor with ( now) DTC-30 pads.
I' trying to find a solution to have more braking power in the rear ( to help with stopping time, help more the front especially now I have more rear weight with fuel cell) without hitting ABS ice mode,
which caps how much pad I can run at either end ,sharper front trips it, grippier rear snaps the car. C1/DTC-30 is the compromise I landed on. ( and I tried many pads)
The three options I looked at:
  • AP Racing / Essex CP9450 rear kit — $4,849
  • Wilwood AERO4-MC4 rear kit — $2,353
  • Do nothing, chase it with compound
Clamp and torque math ( with help of AI)
Effective radius = rotor radius − (pad radial depth ÷ 2). That's the lever arm. Torque ∝ clamp area × eff radius × μ. For a floating caliper the single piston area counts once; for a fixed caliper you count one side only.
CHECK THE FIRST PICTURE
results :OEM is actually the best for clamping force.
550 OEM rear
— 355.6mm x 28mm 2-piece rotor, 47.8mm pad, single 45mm floating piston, 15.9 cm² clamp, 153.9mm eff. radius, torque index 245
Wilwood AERO4 — 355.6mm x 20.6mm rotor, 72.9mm pad, 4-piston fixed (2x 28.4mm per side), 12.8 cm² clamp, 141.4mm eff. radius, torque index 181 (−26%)
AP Racing CP9450 — 340mm x 28mm rotor, 42mm pad, 4-piston fixed, 13.6 cm² clamp, 149mm eff. radius, torque index 203 (−17%)
Both kits are nominally weaker than what I already have. My 45mm floating piston is simply more clamp area than either fixed caliper brings, and my 14" ring already matches the Wilwood's diameter.
Watch the Wilwood line — biggest rotor, shortest lever arm. That 6617 pad is 72.9mm deep and eats 36mm of radius. Rotor diameter alone tells you nothing.
So case close? not yet.
Why the strongest option is still the worst one
A single 45mm piston loads a 149mm-long pad from one point in the middle. Consequences:
Heat concentrates. Same energy into a fraction of the pad. The center band cooks past the compound's ceiling while the pad ends stay cool and contribute nothing. Once μ starts dropping with temperature, it drops in the loaded zone first. it other words, the clamping force is still higher BUT cannot be use 100%.
another point on the single-piston list, and I suspect it's the biggest one:
we said that A floating caliper doesn't push the outboard pad with a piston. The piston pushes the inner pad, and the caliper body slides on its pins and reacts backwards to pull the outer pad in. Every bit of pin friction, stiction and bridge flex is clamp force that never reaches the pad. (I'd estimate 10–15% loss??), worse once the pins are hot and full of cooked grease
It tapers. The piston pushes at the pad center, friction drag acts at the rotor face, and the offset rotates the pad against its abutment. Nothing resists that with one central piston. My OEM pads came off with one side at end-of-life and the other still half thickness. That's mechanical, not thermal — and I suspect the cocked leading edge clipping into the slots accelerates it, especially on a soft compound.
As it tapers, contact area collapses, so torque bleeds away through a session rather than fading cleanly.
Fluid heat. A 45mm piston face is a wide conduction path from the hottest part of the pad straight into the fluid.
I want to be clear that I can put hard numbers on the torque table but not on these. Iunderstand the concept. but cant talk about real numbers.
The case for 4-piston despite less clamp
Two pistons spread along the pad length apply load at two points and resist the rotation that causes taper. More of the pad works, local pressure drops, heat spreads, wear stays even. Fixed mounting removes slide-pin stiction and hysteresis — which also matters for ABS, since the controller modulates at 10–20 Hz and needs torque to track pressure without lag.
A floating caliper doesn't push the outboard pad with a piston. The piston pushes the inner pad, and the caliper body slides on its pins and reacts backwards to pull the outer pad in. Every bit of pin friction, stiction and bridge flex is clamp force that never reaches the pad. I'd estimate 10–15% loss, worse once the pins are hot and full of cooked grease
The thing that made the decision for me: grippier rear pads make my car snap. So I'm not rear-torque-limited — I have surplus rear torque I can't spend. Losing that 17% ( AP racing kit) nominal costs me nothing usable, and it converts into headroom to run a higher-temperature rear compound and land back near the same axle torque. Right now DTC-30 is my ceiling purely because anything grippier is unstable.
Bias goes from 21.4% rear to 18.4% rear — recoverable with compound. so again, not optimal but is an option.
Where I've landed: AP CP9450, rear only, front untouched. The Wilwood does the same trade but hands me a 20.6mm ring when I'm already on 28mm, which is backwards on the one thing my current setup is genuinely good at. less rotational mass tho. but how much bad would be ?
ONE LAST TEST : pulling the DTC-30s to see if they taper like the OEM pads did ( SEE THE PIC),which I use to helping me with snapping but of course no good for more than 3 laps ( time trials) and checking the slide pins. If the pins are binding that's a chunk of my taper for $50, and it changes the answer.
Questions for YOU :
  1. What's your thought on this?
  2. $7K ABS or 9k hardware?
THANKS IN ADVANCE GUYS,
Alessandro
ps.AP RACING front kit is smaller than my oem .Why go below OEM rather than match it? Less piston area means less fluid displacement, so a firmer pedal and with far better pad volume and cooling you don't need more torque. I dont need the peak; I need concistency. and maintain the bias with their smaller rear.
I'm going to read this through about a dozen more times and throw some numbers at it as well. You got me curious.
And that picture, you making wheel chocs from brake pads. DAMN. That is some angle.
Please. And let me know. Cause insanity here is increasing too fast lol
Oh boy lots of numbers! Not at all surprised that the stock brakes are better then choices from the likes of Wilwood. Never seen wilwoods do well on heavy fast car, would assume it would be a downgrade. And CSG C1 pads?? for your car?? Goodness!, is that to give the competition a handicap?? Maybe you are just going way over the temps for those?? Even a gloc R12 has a 250C higher max temp. Maybe you are just cooking those GSC pads?? I love the combo of Gloc R18 Fronts and Gloc R12 rear. They take a lot of heat!
Here is a comparison chart for the rears.
The front are perfect. The rear are cooking. And to be fair. I used OEM cause it was the best balance forn2 laps. Not i tested dct30 after changing setup and weight of the car and they did good. My car get with C1 and oem Rear 1.7-1.8g in braking. So C1 are in my opinion the best to avoid icemode.
I dont like gloc (super noisy and icemode a lot)
What i would love is the modulation of c1 with a touch more bite. And I hope I can give that bite with better rear.
Wildwood is the brakes spec Corvette use. Yeah lighter than us but not a miata.
My concern is the 20mm vs 28 thickness for heat managment.
Lastly. I need to come up with a Inlet for the brake cooling in the rear.
I know you said that grippier pads make the car nervous, but at least in my case, low temp pads will not last 40 min. Then again a set of Pagid RSL29 pads are less grippy. take high temps and last for ever. But you have to sell body parts to get them (and not the cars...). We used them to win a 3 hour Enduro race and the brakes never faded and had plenty of pad left at the end.
C1 is lower temp than others but still
750C. but again it do TT mainly so far but I did try race simulations and they were pretty good. I tested the pagid and they didnt work for me unfortunately.
I'll give you a few more things to think about. The rotors are constantly heating up under braking and cooling down after, and the front and rear rotors may not be at the same temps at the same time. Different pad compounds typically have different friction at the same temp, but a single compound may also have a curve in its friction-to-temp plot, even in its ideal / working range. Hawk has a web page that shows friction plots for all their race compounds. Generally, if you're mixing pad compounds, you want to choose compounds that maintain the same differential in friction over the temps you're getting at the same time in each rotor. To do that really right, you have to know not only your front & rear rotor peak temps, but what they are through the whole braking cycle.
I was curious about the "ICE mode". With the Mustangs that are tracked down here it only seemed to appear in automatic cars. When one mustang made a swap to manual and the problem went away. :idontknow:. He though it was to do with brake vacuum.
I am curious how the GT350 rear kit would factor in using the 380mm rea
I increased the brake vacuum thanks to addition canister. No change.
What it helps is the engine brake (now with the sequential.)
I just talked to AP RACING
they dont recommended rear kit only.
They said the ice mode is actually due to a roo strong rear brake. So their kit moves forward the bias even more. This Matches what I feel actually. I have less ICE MODE WITH REAR OEM PADS. In other words because the the rear is worse from a
Clamping force it doesnt trigger that much the ABS.
Which sucks cause it reduces the overall braking capacity.
I've had a good experience with Cobalt XR1 and XR2 pads on my 500 and we also run them in brembo race calipers on an s197 boss 302s endurance car. Coming from Fero 3.12s and glocs on my car, these have as much raw power, with better rotor wear. They also can custom make pad shapes and deliver very quickly.
I use their XR1 pads in gt350 brakes on my 4000lb gt500 and it can take a lot of abuse. Tey also have all their compounds for my rear pads, so I was able to run Xr1 rears which helped my overall braking distance and reduced front ABS engagement. In the boss 302s we just ran 9hrs of a 14hr race in warm temperatures, and they were unchanged braking from 150 into turn 1 for the whole race - too bad the transmission did not last as well!
I would go with some 4 piston rear for better pad wear consistency and brake feel/release. Maybe oem GT or gt350/500 rear. The gt500 rear uses an electric parking brake, so the rotor hat is smaller and lighter. And rotors are cheap ($600/pair) and can be turned when worn down. https://www.ebay.com/itm/3641582947...Z31GGtrGbMmSdUlsXVKeZvi7o=|tkp:Bk9SR7Th0ZL5Zw
I would go with some 4 piston rear for better pad wear consistency and brake feel/release. Maybe oem GT or gt350/500 rear. The gt500 rear uses an electric parking brake, so the rotor hat is smaller and lighter. And rotors are cheap ($600/pair) and can be turned when worn down. https://www.ebay.com/itm/364158294791?_skw=gt500+rear+rotor&itmmeta=01KZ4JME166092DCNA5NGPCTS0&hash=item54c9869b07:g:HKMAAOSwH5hoWmo8&itmprp=enc:AQALAAAA0GfYFPkwiKCW4ZNSs2u11xAMWzy45hfFtqask76m7UqwMTkQJJKr/2CzcTGOaInVgHJSPT5fqWc0kOFj+eeQSg61iqK4NS9IGOHMwqzVUg1Ss0KAUugCQjM2cCFF6U4W0iRc2YnwmVN7Sz+dYHF5Gfg09T6/r/XI9usAbCFes+DPYhlMhcyiyIpMZVkcSj3TuIlp5AYnJLQL+P1z3t8XrwWtx7ml/76Q1/cXEasH/44KxlFZXhC0mQfp4vA07sZ31GGtrGbMmSdUlsXVKeZvi7o=|tkp:Bk9SR7Th0ZL5Zw
According to APRACING it is actually the rear triggering the ice mode. So THEY SAID REAR less aggressive might actually help
