domesticpower
Track Addict
Just under two weeks ago, I started noticing some rear end noise. The noise sounds like a squeaking/creaking intermittent noise (i.e. a short and distinct squeak or creak as the suspension moves up and/or down). The noise is louder in right hand corners than in left hand corners. There is no noise on straight roads and flat corners and even big bumps that are even side-to-side don't seem to be an issue. Cambered/bumpy corners cause the noise.
Suspension/chassis modifications are 18x9.5 wheels in 285/35 tires all around and Fays2 Watt's link.
I'm suspecting the Watt's link, shocks or a bad bushing. I have had Watt's link noises before and I was able to find them and fix them but I can't find anything here. There was a rod end on the Watt's link that was dirty and almost seized but I cleaned it and re-greased several times and it's much better now - I don't think the noise is coming from there but it could be. I checked under the car and everything looked tight. I pushed down on the rear of the car and there was no noise.. not that this completely eliminates shocks and bushings possibilities but I am clueless at this point. Any ideas? The car has 69xx miles and has been to the track a few times.
