Yep. From the press release:jimprw said:These vents are functional on the 2013, right? Hard to tell if the holes are actually open in the photos.
cloud9 said:I really would like a way to evacuate the heat from the engine bay and keep an OEM hood............
Show us how to do it with your Boss hood.ArizonaGT said:cloud9 said:I really would like a way to evacuate the heat from the engine bay and keep an OEM hood............
Cut a hole in it
I saw your post on TMS. My thought is anything can be done it's just a matter of how much do you want to spend.06mach1 said:To install those vents in our 2012 hoods would require the bracing underneath cut out as there is not an opening long enough for those vents. It will be interesting to see if these are available separately, as the GT 500's vents are. If they fit without too much altering of the bracing underneath, they would probably work. The lip of the vent would just stick up above the hood. It would not need to be recessed like the 2013.
You need to think a little harder.adam81 said:You guys are thinking way too hard here........
Order a complete 2013 hood and have it painted.....
After you either put all the time into it yourself or have it done I bet you will be almost equal itself out....
5 DOT 0 said:You need to think a little harder.adam81 said:You guys are thinking way too hard here........
After you either put all the time into it yourself or have it done I bet you will be almost equal itself out....Let us know when you figure it out.
No worries. I wish I could just order that hood and have it painted. The TR hood is an obvious choice but I'm not sure I want it on a car that will be mostly driven on the street. It sure looks cool though.adam81 said:You got me.... A few to many tonight.... I get it. Damn micro brewery and phone internet.... But still, easy answer..... Tiger racing hood..... You really shouldn't be worried aboutt a few rain drops... Ford isn't....
5 DOT 0 said:No worries. I wish I could just order that hood and have it painted. The TR hood is an obvious choice but I'm not sure I want it on a car that will be mostly driven on the street. It sure looks cool though.
