Sorry if this topic was discussed before, but I need advice on a "realistic" track alignment for a 2017 GT350 (non R).
The supplement in the 2017 owners manual specifies -1.50 front camber for track days, but I was advised to use no less than -2.00 front camber for track use. But if I use -2.00 front camber, what should the other settings be? I noticed that the "2019" supplemental manual shows much more aggressive track settings, but will this work for my 2017 vehicle/suspension...?
I don't want to change "only" the Ford recommended track camber specs without knowing what the other settings should be too. Is there any difference between the 2017 and 2019 GT350 (non R) models? If not, why did they change the recommended track alignment specs for later manufactured GT350s?
Thanks in advance.
Thanks in advance.
