A rebuild with priority on cooling is likely the way to go. Will your current system get you buy with cooling improvements? It could. Remove the shields in the rear and replace the fronts with ducted shields. 3" for sure. The cost difference is minimal between 2.5 and 3 and no real cutting is required for 3". Rear brakes? Most of us run stock calipers on the rear. Remove the dust shields and bleed off fluid each day and they work. Some have installed the larger GT-500 rotors with either a spacer on the stock system or with GT-500 mounting brackets.
The key will be cooling. Get as much air to the rotors. Ducts on front and removal or the shields in the rear. The Boss owners supplement suggest this.
Titanium shields are a must for the front. I have not needed shields in the rear.
Consider a system which can use stock size rotors. Several members here have done this for convenience and economy. I still run the stock brembos. A rebuild every other season has been enough for the front calipers. Rotor blanks under $100.00 are the main reason to consider stock sizes. Brembos from a GT-500 or Boss come to mind. Stock blank rotors are low on bling but high on logic. Some tracks consume brakes regardless what you do. Road America is one. Long straights with serious braking zones, 3 per lap. Long cool down between braking points.
If you will be slowing from 145, much like at RA, brakes will require replacement of rotors and pads often. I ran 10 track days at smaller tracks on one set of rotors and two sets of pads. One weekend at RA slowing from 145 on the front straight, 135 going into 5 and 130 at Canada corner and a set of brakes was consumed in one weekend. Rotors and pads gone.
Finding a way to reduce the cost of consumables is a good idea. Stay away from drilled rotors, they like to crack at the holes.
Ironically, running a economical system may not save you money. Somehow we always find a few more track days to spend the savings on.
Good luck with your brakes.
