- 6,401
- 8,295
It looks like Phoenix will be running a limited schedule next year, which means I'll be available for track days. The going rate is $150/day plus expenses, (in Florida).
I can handle up to 2 cars at a time, if I get some competent help, and some cooperation amongst the drivers, then up to 3. (that's $50 each car)
I'll do the pressure/temp calculations and make recommendations.
What I need from you are..
Size, type and brand of tires
High psi target
amount of pressure gained from cool to hot,( if not I can get in in the first heat cycle.)
access to a large compressed air tank, compressor or nitrogen.
You get a recorded history for future use.
I can be reached at 813 382 0271 text only plz.
High psi target
