whould you suggest the Hardest rubber insert when using MGW with your Blowfish Bracket?
JScheier said:I'm beating this blowfish bracket like a rented mule here in Hastings at Mustang Roundup. Limited vibration, no noise and shifting has been spot-on all day including full-throttle, hard sweeper shifts from 3-4 at least 8 times a session with no issues and the same amount of 4-3-2 downshifts each session.
I swapped to harder race bushing. No noise or harsh vibration. Bangs gears like my old 3650 TriAx'ed Bullittpufferfish said:Good question. What say you, MGW users?
I've spoken with George extensively about this and he believes that the harder you make the rear mount the more NVH you will have. I'm using the softer bushing and have no need or desire to switch it to the harder bushing.Pitt302 said:whould you suggest the Hardest rubber insert when using MGW with your Blowfish Bracket?
George is undoubtedly correct for his shifter in the stock configuration, but it's an entirely different ball game with the blowfish bracket.skwerl said:I've spoken with George extensively about this and he believes that the harder you make the rear mount the more NVH you will have. I'm using the softer bushing and have no need or desire to switch it to the harder bushing.
Actually my shifter is working great and I couldn't ask for anything more. My issue is with the cheap Chinese transmission clunking and clanking with only 4000 miles on the car. When I removed the driveshaft from the trans I could turn the output shaft by hand back and forth about 1/4" and reproduce the clanking noise I hear while driving.Ultrakla$$ic said:Brian, switch to the harder durometer bushing and see what happens. I trust your input.
skwerl said:Actually my shifter is working great and I couldn't ask for anything more. My issue is with the cheap Chinese transmission clunking and clanking with only 4000 miles on the car. When I removed the driveshaft from the trans I could turn the output shaft by hand back and forth about 1/4" and reproduce the clanking noise I hear while driving.
pufferfish said:George is undoubtedly correct for his shifter in the stock configuration, but it's an entirely different ball game with the blowfish bracket.
If it's a defective part then MGW is very easy to work with. Give Julie a call and I'm confident she will get your situation resolved. Really good people there.Calif boss302 said:So I installed my MGW shifter today. Jack stand to hand washing 3hrs which included running up stairs 3 times to watch and rewatch the install video and removing the mounting arms bolts because I forgot the loctite.
All went well and the new shifter shifts great. Very crisp and firm. Reverse is a bit stiff but that should loosen a bit.
But here is the kicker. Went to install the MGW shifter ball with the included new lock nut and washer and the brass bushing inside the ball is loose. I installed the lock nut collar then the lock washer the screwed on the knob. Did not tighten the knob too tight. Used a wrench to screw the lock collar up to tighten the ball. Now its loose. Uggggg! Put the stock knob and collar back on for now.
Not sure what i did wrong there . .
Anyway I'm going to drive it a few miles before I install the Blowfish Bracket.
