302 Hi Pro
Jason said:The TSB # is 13-12-5. Ill list the parts they replaced and the write up on the page
Hub Syncro
Ring synchro
Output shaft bearing
Counte bearing assembly
Support plate
2nd gear main shaft (5%)
snap ring
gear shift rail
fuid and a nut and gasket for the exhaust that was rusted.
Diagnose for intermittant grinding 1-2 upshift at slow speeds and low rpm. Scott duplicated with customer. Confirmed second gear grinding. Found TSB 13-12-5.
Removed trans. Seized exhaust bolt mt. Mounted trans in holding fixture Disassembled trany as per TSB. Found debris on magnet. Second gear damaged. Center support shift fork bearings damaged. Require complete inspection TSB no longer applies. Comlete inspect damage only at second gear and 1st second synchro and center support with reverse shift shaft. Installed new parts assembled trans bled clutch test drove no further concernes.
Hope this helps. and yes it was covered by warrenty.
Did this repair fix your second gear crunch?
2HP
