Just gotta convince my wife of that. She's also okay with a 'dedicated race/track car' addition, but 'necessary wisdom' is *not* how she's describe my love affair with cars.kcbrown said:And that means you have gained the necessary wisdom for tackling this problem.
The 'cooling' is just the standard bolt-on brake ducts, removal of the rear dust shields, 302S grille and tranny scoop. No heat issues so far, but I'm not going to run the Boss in the heat like the GT.Nice. Excellent, in fact. It's a bit of a shame that you had to modify the cooling any. I'm hoping I don't have to. I was at Thunderhill recently and didn't have a problem with engine cooling, but it wasn't as hot as I thought it was going to be (it was mid-90s) and because the track was new (5 mile course, no less!), I wasn't really pushing it as hard as I would at a track I'm intimately familiar with.
Yeah, I'm not careless with the GT. I will leave it in a parking lot unattended, but I'm still selective about parking spaces. The Boss is never parked unattended.Same here, although I love my car enough that I do try to park it someplace where someone isn't going to bash their door into it...
Quadrabind...exactly! The two '00 GTs barely had good enough suspensions for drag racing. Sadly, the balance of the 'vert was better for any turning.Well, here's the thing: there's a difference between how a car responds and how it performs. The McStrut front suspension limits how the car will perform, but doesn't necessarily limit how the car responds. That's likely to be much more related to things like the choice of bushings than the specific geometry.
But it depends. The quadribind suspension of my 92 GT, and the geometry of its suspension in general, made the rear end feel horrible. The difference between that and my 2014 GT is night and day.
So it's really going to come down to a question of how much of a difference in response there is between the Boss and the GT350. I expect the GT350 to perform better, but I don't know that it's going to respond significantly better. And the latter is what influences the driving experience. The former is what gets you lap times. If you're not chasing lap times, you're probably after responsiveness and feel more than anything else.
Well, it would be nice to have a car that does what the Boss does performance *and* response wise, but doesn't have issues with front tire wear patterns and 'V' gutters or track curbing. Would be nice to always have a better connection and feel even on a beat up track like Streets of Willow. Would be nice to have a car that doesn't have to solve tire wear with excess static camber.
It probably has a lot to do with the lack of lumbar support too. I remember the Cobra seats feeling better on a long drive. The Recaros were definitely not great on the two trips to Laguna Seca.Seats are such an individual thing, though, that I certainly can't fault you for your preference...
It was stock. I'm sure it would take more than just dampers and sways to completely close that gap. I've been on track in the GT with other suspension modified Cobras, and they were easy to leave behind even in tight sections.Were you still using stock dampers on the Cobra? I have to wonder if coilovers plus an appropriate sway bar package would have closed the gap between your Cobra and your Boss.
I guess I'm a lot more confident in the changes and engineering ability of the current staff. All of the incremental changes should add up to something good *if* they do it right, and I think they will. Even if we have to thank GM a little for raising the bar enough to ensure a good response from Ford. Looking at the figure 8 numbers above, I suspect they're on the right track.In any case, technological improvements make a huge difference here. The Boss suspension is simply better engineered than that of any previous Mustang. But I'm quite skeptical that the engineering of the GT350's suspension will be so much better that it'll be a major difference.
I hope I'll have that opportunity! Sometimes dealers are stingy about the special model test drives around here.It'll be most interesting to see what your impressions are of it once you get a chance to drive it.
