The s550 so called dyno plug
4-wire pin connector into a plug cap w loop green wire.
We have lost the dyno plug cap.
Anyone know what 2 wires on the 4 wire harness side connect ? When the cap is installed. Im going to install a switch in the cab. Will allow to either close the circuit or open the circuit for stability and traction control off.
The 4 wires are
1- solid green
2-green w yellow trace
1-gray
What 2 wires connect when cap is installed
Thanks in advance
The 4 wires are
1- solid green
1-gray
Thanks in advance
