S197 Eric's Candy Red S197 Build Thread Profile - S197 Mustangs
1,170
1,169
Lenoir City TN
I was just posting a long over due review of the pads. See the new thread I just posted.
1,170
1,169
Lenoir City TN
Okay, I had some brake cooling hose inlet ducts designed and 3D printed to facilitate changing hoses as needed. I was tired of removing the front bumper cover to change out the 3" hoses each time I caught them on a tire. This new routing should also help keep the hoses away from the tires. The ducts did not come back as far as I was thinking, so I can't change them from the wheel well like I was hoping. I still need to remove the plastic splash guard underneath, but do not have to take the entire front end off. These were designed to fit the 2011-2012 front end with the Boss/CS lower fascia using the fog light openings with 3" cooling hoses.
164
319
Chicagoland
View attachment 90163View attachment 90164View attachment 90166View attachment 90167View attachment 90168
Looks great! Any chance you’ll be making more/selling any?
1,170
1,169
Lenoir City TN
I have already paid the engineering/design costs. The printing is the cheaper part. The print job takes around 10 hours per side. The shop that did it for me can print more. I am waiting on the price to reprint them. I should no more in a day or two.
1,170
1,169
Lenoir City TN
I just heard back. It is $265 to print each set. Remember these were made to fit the 2011-2012 Mustang GT with the Boss/CS lower fascia and 3" cooling duct hoses. I need to look at a stock GT lower fascia and see if they will fit the back. If so, it may be possible to run a hold saw through to open up the holes. If anyone is interested in a set pm me and I will get you the information to the shop that designed/printed them for me.
1,170
1,169
Lenoir City TN
Regular GT lower fascia isn't going to work. I thought it had the molded in fog lights without the cutouts, but I was mistaken. That design is one I've seen but don't remember where.
100
145
Olsburg, KS
What material did they use for the inlets? I've got one side done on my Bullitt, but have abandoned the other one for now, as they both need a bit of redesign. I used nylon for the one that's done, but will eventually get them both made in ASA.
1,170
1,169
Lenoir City TN
I'm not an engineer and will not pretend to know the structural properties of the different materials. I do not have the design skills and no nothing about 3d printing. I know my limitations. That is why I farmed this one out. I was not a cheap project but I am happy with the outcome.
1,170
1,169
Lenoir City TN
Most likely nylon. It's a fairly common combo, but I haven't tried it yet. It's fairly expensive, so I'd want to be pretty proficient at getting things set up before I try it. Standard ASA is still kicking my butt at times.
He talked about using a carbon infused material initially but ended up using ASA in the final product.
1,170
1,169
Lenoir City TN
The carbon infused wouldn’t hold form and was losing its shape during printing. He said other cooling ducts previously made from carbon infused material started to show cracking with age. They switched to ASA for durability and printability.
100
145
Olsburg, KS
I've got several ASA pieces under the hood of my car that have already been through about 4 track day events and they still look new. I switched from ABS when I found out it was very similar, but also had UV resistance. It's way trickier to print than the standard PLA, but it is definitely way more temperature resistant. I'm sure I'll use ASA when it comes time to try making the ducts again. Good to hear he's had good luck with it.
1,170
1,169
Lenoir City TN
Fixed a leaky pinion seal, changed trans fluid and gear lube in preparation for the trip down to Barber on Thursday. The pinion seal was leaking between the metal flange and the housing. I must not have gotten it in right when I did the gear swap last summer. Also noticed something didn't look right with the rear trailing arms when I was under there. The angles looked different.
Somehow I managed to put one arm in the upper hole and the other in the middle hole. Not sure how long it has been like that, but it has been a year or so since either one was off. Had to pull a wheel and the sway bar to move the bolt.
