You must be getting close to having your final car weight??
Pretty close, got some more pressing things to complete but we aren't very far away from it.
What Cam is that???? Sounds more aggressive then the LM intake cams.... or with out the tune installed?
Its the L&M cams.
I don't have the power brakes hooked up and the hole for the PCV just has tape over it....we aren't 100% yet, I just wanted to hear it fire. And it did.
Its just a stock junk yard motor with L&M "intake only" cams and some bolt ons, I doubt it will sound that healthy when it's tuned and has mufflers on it but it didn't smoke and I didn't hear any rods knocking or have oil spurting out etc.
I'm calling this one a win....at least for now.
So you guys with newer full race cars...do you typically do straight pipes out the sides or mufflers all the way out the back? I know what I would do.
Not around here, you have to be 90 db to run at Laguna Seca and 103 at sonoma and Thunderhill.
Atlanta Motorsports Park has the same requirement. I suppose I might not be able to run there. 😒
Certain days they have 103 db but its few and far between not to mention pricey.
For my SCCA races its 103 db so I can make those....just can't use it for a test day.
Probably going to test at thunder hill.
