Ford performance steering wheel
Discussion in 'Boss 302 and S197 Technical Forum' started by Mad302, Jun 18, 2018.
  1. Mad302
    Mad302 TMO Race
    335
    109
    Sep 2, 2014
    Waco, Texas
    For those of you who switched to the ford performance wheel how did you retain the steering wheel controls. Especially those with 13-14’s.
    Thanks
  2. gripdriver
    gripdriver TMO Race
    207
    103
    Jun 27, 2017
    Arizona
    I ditched the controls that are for the radio and other useless crap. I kept the ones to adjust steering feel, reset mileage, reset oil changes etc etc.
    I removed the clock spring, electical taped it so it would not separate, or turn. Then I zip tied that under the steering column. My controls are zip tied to a wire harness near the OBDII port (near the top of the driver kick panel)
    its really easy once you look at it for a minute.
    (I did not use the ford performance wheel, I went with a 350mm Personal wheel)
  3. Mad302
    Mad302 TMO Race
    335
    109
    Sep 2, 2014
    Waco, Texas
    Could you take some pictures of it and pm them to me? I get what your saying but would just like to visualize it.
  4. gripdriver
    gripdriver TMO Race
    207
    103
    Jun 27, 2017
    Arizona
    When you remove the factory steering wheel, and mount whichever hub you have, its easy to visualize. You will see.
    just remember to tape the clock spring in place so the two halves do not separate, or fall apart while its up under the steering column.
  5. cholmes1
    cholmes1 Charles
    146
    52
    Jan 6, 2016
    Denver, CO
  6. Mad302
    Mad302 TMO Race
    335
    109
    Sep 2, 2014
    Waco, Texas
    I had it installed and managed to retain all functions of the steering wheel buttons. Taped the clock spring and had it under the dash and wiring was long enough to keep all buttons.
  7. cholmes1
    cholmes1 Charles
    146
    52
    Jan 6, 2016
    Denver, CO
    This post is a bit confusing. How did you keep all steering controls in a swap to a Ford Racing wheel?
    Can you share a few pictures of your setup?
  8. Mad302
    Mad302 TMO Race
    335
    109
    Sep 2, 2014
    Waco, Texas
    I don't have any pictures of the wiring harness. The wiring for the steering wheel buttons is quite long. You just route the wiring up and put the buttons on the dash with velcro. Now you will need either a quick disconnect wire or stretchy trans brake wire for the horn and that's about it really. Once you remove the clock spring and lower dash you'll see there's a ton of room there.
    The picture is before i put the velcro on buttons and put right on the dash
    cholmes1 likes this.
  9. cholmes1
    cholmes1 Charles
    146
    52
    Jan 6, 2016
    Denver, CO
    So you were able to extend the steering wheel controls out of the column and place them on the dash using the existing wiring. Great work and thank you for your photo.
  10. Mad302
    Mad302 TMO Race
    335
    109
    Sep 2, 2014
    Waco, Texas
    Where i had the clock spring basically behind the light switch i didn't need to extend any wiring which i thought was great. Now keep in mind you may both sets of buttons on one side which didn't bother me at all.
    I'll be reinstalling the setup in the wife's car once she gives me permission to as well :)
    TymeSlayer likes this.
Share This Page
