girodisc rear rotor
344
Black Boss said:
Yes, using Girodisc front and rear, direct swap.
Upgraded to Pagids at the same time - great improvement, and less weight.
Replacement rings are available direct from Girodisc.
- How has wear been?
Are you getting any heat checking?
thx for posting..
Don't you get heat checking on all rotors?
344
yes, right-on.
Just want to know how severe & whether heat checking is a replacement factor with girodisc.
I also suppose it depends on driving style, etc.
I do also realize the pagid is a more intermediate pad than what I use, but any feedback is appreciated.
1,936
2,036
Michigan
Heat checking is not an issue on rears -- ran them all the way down to 17.4mm.
Fronts I replaced after 18 days on track, close call on whether they will wear or heat check first. I took them off before they were done to have a spare bedded set in the trailer. They were worn down 1mm and showing some significant heat checking.
Am changing front pads about every 6-8 days.
344
- did you have issues with break in on the fronts or was that normal?
7,556
5,291
I have Girodisc and Pagid set up.
Once I Properly bedded the front I have had zero issues.
I had the brake ducts open the first time I bedded the pads. Mistake.
Cleaned up the rotors and taped up the Intakes and it worked like a charm.
Stop great.
I see wear on the rears from spirited highway driving if I leave the traction control on.
Replacement rings are reasonable.
Recommend.
344
Stop great.
Recommend.
I ordered Girodisk rears.
Will post back with results using Hawk DC-60.
Thanks to all who posted.
Lee.
- On another note, anyone know if there is 3rd party availability of rotors for Baer hats (fronts)?
1,936
2,036
Michigan
No problem with break in. Make sure to block ducts.
Update on pad wear. 6-8 days was with Pagid Yellows. I've moved on to the more aggressive Pagid (RST2) and prefer them. However I'm only getting 3 days out of them -- based on 2 sets rotor wear is no greater so far, but looks like they will heat check before they get to minimum thickness. Still expect 18-20 days on the front rotors. Will see if using the more aggressive pad from the start reduces rotor life.....
344
I put GD's on the rear stock brakes, (Baer 6R on front).
DTC-60 on rear, 70 on front.
So far so good on the rears.
Will post back after a few more track days.
Also spec'ing some custom rotors for the 6R's will post when done with that too..
