1,937
2,038
Michigan
Starting to move on to Aero.
Based on experience with the R (crazy hood lift) I'm going to put a large center vent in the Hood
Dropped the Hood off to have the GT4 center vent installed before Christmas. Concluded that the GT4 side vents would likely reduce structural stiffness in the OE hood, as there is a lot of reinforcement that would need to be removed in those locations.
Should get it back next week, and expecting the APR wing any day, so Aero should be done soon.....
1,937
2,038
Michigan
Are you planning to use the APR front splitters to match the APR wing or go with the GT4 splitter?
I'm going with the GT4 splitter -- The APR piece is flat and leaves a gap under the 350 or R splitter in the mid section.
Meanwhile, the rear end looks a bit more Racy, still need to add the end plates:
BAW!
1,937
2,038
Michigan
Nice CF Wing Mount reinforcements in the Trunk:
Added the Trunk latch today, and then powered up the Car to check for Door/Trunk/Hood open warnings -- all clear. Door connector is Pin 9 both sides. Hood is obvious. All need to be grounded.
