JScheier
Too Hot for the Boss!
2012YellowBoss said:No next week. I did not beat up the sides too much, this time it was the center that took the worst of it. I was actually running the pressure lower for the first three runs 38.5 so I add just a little bit after the third run. The after the forth I had to let air back out. I think after speaking with an experienced racer I will go down to 36 and see what it looks like. The center strip of each tire is worn down to the inside flat area on one side.
Good indication of over-inflation. Getting the right hot track temp takes some time... you'll get it Anyone around with a pyrometer that can help you get temps right as you come off the track?
The main issue is shifting into gear before the turn rather then doing that in the middle or end of the turn. I had the back come out twice and it scares me or is it at least in the back of my mind and I don't shift correctly. At least I am shifting now, that is an improvement since the first few days I was hardly shifting at all except on the straights.
Are you heel/toeing? If not, then work towards that... practice on the street. If you aren't rev-matching in any way, when you release the clutch, the revolutions of the motor are lower than that of the wheels and will momentarily lock the wheels... which can easily unsettle the car in a turn. Downshifting and braking in a straight line until you get heel/toe down will assist you with corner stability Many pro-drivers do not heel/toe. You can still be fast without it!
I need to just slow down some more when entering a turn. Even if I slow too much that is better then going faster and doing it wrong. If this car was not in such total control out there I would have hit many walls by now.
Slow in, fast out... it works!
