- 6,571
- 8,233
- Exp. Type
- W2W Racing
- Exp. Level
- 20+ Years
I have an extra hood....lol.Wow... 3% hot dang!! Got to sell some body parts
What’s the price tag on that one?If you're going to throw around money, there is this option too https://6xdgearbox.com/ ... frigging thing costs almost as much as I paid for my car!
I was thinking more in the lines of a Kidney!I have an extra hood....lol.
I was thinking more down stream from the kidneys. They come in pairs and they are probably going to want both if them.I was thinking more in the lines of a Kidney!
Like I said before I might have to remove more aluminum like the amount you did.Mines working perfectly
Thats a stripper tree?
Man, I'm gonna have to drink a lotta beer to get enough cans for that!I saw the starting price at $19k and then there are add-ons from there.
Yeah, I think I took more than I needed but for the whole 1 1/2 laps I got on the car it seemed fine.Like I said before I might have to remove more aluminum like the amount you did.
I looked at a lot of different things last time around and ultimately decided it was not worth the cost and headache of switching everything over to a different unit.Thought about that! But to be honest two of my competitors run bimmer dct's and they have no end of problems. Both in programming and in temp problems. But I think Vorshlag has a right up about them.
I don't find anything about the mt82 to be fast shifting matter of fact it's a dog reminds me of the old four Warner transmissions for the trucks back in the seventies those were die hard they would never quit but when you went to shift from first to second you would always have that hesitation and neutral you had to pull it wait a second and then it would pull in the second mg 82 reminds me of that there is no smooth transition at least not with mine I've got a double disc clutch mgw shifter it's the best it can be and it's hardly fastYah I totally get the heat from RPM, upshifting and especially downshifting. If not done properly, (I double clutch on the way down) downshifting really beats up the synchros and generates a LOT of additional heat in a localized area. I've not had an MT82 apart yet, but I assume they have some type of clutch facing on the blocker rings, which makes them grippy and fast shifting, but probably doesn't survive the rigors of road course use well, hence the comments I've seen other members make about dog rings LOL.
I'm just trying to satisfy curiosity here and wondering if I should get a hold of a core and start looking into it myself. There are TONs of these transmissions out there, and if there was a real solution that was cost competitive with the Tremec, I'd think it would save lots of headaches. I get what Calimer is saying when he refuses to stand behind an installed trans. In his mind if it's got 6 forward gears and one backwards gear and it spins over on the bench it's a good unit. The issue is it's not that simple in real life, and admittedly road racing is the harshest environment and the customers are low volume compared to all the mouth breathers that drag race. So I'm sure when a road race guy starts having failures he doesn't have a good answer, and it's not his bread and butter anyway...
I would not recommend anyone rebuild am MT82 after what I went through. The Magnum XL was designed as a replacement for the MT82. They are available new and aftermarket support is much better than the MT82. It is a very common swap with lots of support available in Tennessee. There are Tremec Elite Distributors in Cookeville and just south of Knoxville in Rockford.Well there's a rock solid review. Mine is ok, but at 125k miles I now know for sure it will be replaced, not rebuilt. I also talked with a friend who owns a shop near here and he said they swamp so many of the Magnum XL's into Mustangs.
