No; there is an inline filter just under the driver's footwell. You can see it once you jack the car up. It's got a plastic cover over it.
http://iihs.net/fsm/?dir=968&viewfile=Fuel%20Lines%20and%20Fuel%20Filter%20-%20Exploded%20View.pdf
Here is a guide that says "05-10" but the procedure is the same for our cars. http://www.americanmuscle.com/fuel-fitler-0510-install.html
Relieve the fuel pressure first by pulling the Fuel Pump relay out of the engine bay fuse box, then try to crank the car for 4-5 seconds (it should not fire; if it does just let it die).
