- 24
- 0
Hey Guys, I've been a long time lurker of the forums and value all of your advice but I have a bit of a situation. I just recently installed the Dynotech Drive Shaft, which works great by the way, and decided to recheck the torque on the bolts that I had installed.
As I'm jack up the car, using the differential with chocks on the front tires the car's rear end wiggles from side to side. Kinda scary but I put my jack stands under the axle as usual and proceed to check the bolts. Drive shaft is fine but on my way out I notice that my panhard brace is diagonal and the panhard bar, which is directly below it, is parallel to the ground. I get out from under the car and my passenger rear suspension is lower than my driver side if that makes any sense. The rear sway bar seems twisted and I would dare say that the spring and damper seem fully extended on the passenger side? I don't know exactly what I broke in this situation.
I'm sorry to ask you guys such a newbie question but I can't seem to find the right info via google, so I turned to you guys for help.
