Help with Rear Suspension
pufferfish
Supporting Vendor
1,094
66
Maryland
sorry, I assumed you were asking about angle. there are some that allow you to set the angle as well as the length. if you don't have that adjustment, you get what you get. so just set the length so that the tires are equidistant from the fender.
6,402
8,300
pufferfish said:
the panhard bar should be positioned as close to parallel as possible with the suspension loaded and at rest. I go with a slightly downward angle (axle mount end lower) to account for passengers, since the suspension will be compressed more with people in it...even if its just the driver most of the time.
Yes, excellent advice. Go borrow some of your friends weights and pile them in the seat(s) and then you won't have to guess. (Being 235 I have to borrow a lot of weights) :-[
