It is so unbelievably easy to install. You simply slide back the retaining clip at the cam cover and intake and pull off the factory hose. Reverse the process to install the JLT unit. Took about one minute literally. I have not seen one from Ford Racing, but JLT uses Ford factory hoses and it's incredibly high quality.5 DOT 0 said:Any tricks to installing it? Do you know if Ford Racing makes one?
There's a significant amount of oil vapor released due to crankcase pressure and then pushed back into your intake to burn it off. The oil can coat your intake fins and lower your octane. Since the Boss tuning allows timing to vary based on octane, it will rob you of power. A friend of mine is running them on both sides on his 5.0. He gets quite a bit of oil in the passenger side can and almost none on the driver's side. These motors seem to burn some oil from what I've been reading. I burned about 1/2 quart early on, but haven't seen the same since it's been broken in, however it is a good idea to check your oil level regularly on these 5.0 motors.adam81 said:Any particular reason you installed it? What benefits are you hoping to receive from it? Thanks.
Yep ordered it directly from JLT.2012YellowBoss said:Think I am going to do this. I heard the same but did not know how true it was. Good job as always.
What did you pay $119
The Boss 302 R race cars run them on both sides and it was recommended for the street cars if you track your car. This came directly from Ford Racing.cloud9 said:In addition to all of that, Rick talked with someone in the know that recommended it.
Confirmed.Fat Boss said:The PCV valve on the PASS side has a little check valve or ball or some other restriction in it. Apparently it is able to be modified by removing this restriction. The benefit is the DRI side will be less likely to puke oil all over the engine compartment. They do this mod on the race cars, but they use a canister on the firewall. Both PCV valves feed into a T that goes to the canister as I recall.
Andy
I think you should follow your friends experience and just do the passenger side.cloud9 said:Interesting. As I mentioned a friend wit a 5.0 has had virtually zero oil collect in his driver's side catch can. I wonder if this is a necesary mod for cas driven 20-30 minute sessions versus race cars driven 2-3 hours at a time?
Is the valve the light blue piece that connects to the hose on the cam cover? Does it just pull out or how do you replace it? P/N for the driver's side? How will changing it to the driver side part # help?Fat Boss said:Gary a little bird told us to gut the pass side valve (pcv looking thing) or get the PN for the drivers side and use it.
Unfortunately we didn't get a demo on how to take it apart. He said it takes about 10 minutes so it can't be too difficult. The connector from the drivers side doesn't have the valve and might be the way to go in case you want to replace the original on the passenger side. Maybe PTRocks can find the part number since he seems to have access to that info.cloud9 said:Is the valve the light blue piece that connects to the hose on the cam cover? Does it just pull out or how do you replace it? P/N for the driver's side? How will changing it to the driver side part # help?
It's no secret. I believe it's just a one way valve.rom said:JLT orderedcant wait to see what the deal is with that pass valve blockage too
