Interesting Video on Wheel Spacer
I am sorry to ask another question about wheel spacer. Today I accidentally saw a video that talks about this topic: whether wheel spacer is good or bad. He points out it will change the suspension geometry, reduce braking stability, and effective spring rate at the wheel.
What do you guys think about the video?
Since I just ordered a set of wheels that requires spacers to run a fully rotatable setup, I would like to hear you guys' opinions about this topic.
Any minimal loss in handling and braking are more than made up with the additional grip you'll have. I didn't watch this video but the race teams use spacers, along with hundreds of TMO members, so proceed with full confidence that you're making the right move. In our case you're not using spacers to change geometry you're using spacers to make up for the lack of offset needed to clear the brakes and suspension.
“Pushes your wheels out further”. His assumption is that the wheels fit without the spacer. Not what we are doing.
Another YouTube “Professor”
Oh Boy.
i thought the stuffs he talked about are pretty legit. Thats why i wanna bring out this video to make sure i made the right move for my car.
Its good to have such a technical forum like this one. I believe I will have more questions about the car once I start tracking it lmao.
7,559
5,294
The points made in the video are basic and legit. A bit confusing with the short explanations.
What most of us are doing is allowing the front wheels to be manufactured with meat removed so the wheel/tires fit the rears. Then we add the spacers for front mounting.
If he had emphasizes treadwidth location and clearances wheel to fender and wheel to suspension, he could have been clearer. A warning concerning spacers with studs mounted and the use of factory installed studs would also have been useful.
