- Thread starter
- #21
- 6,409
- 8,307
This is how the stock and modified arms should look..the idea here is to completely remove the ability of the upper arm to do anything, except exert force in only 1 direction..you can now also adjust pinion angle..although you will have to remove the through bolt on the swivel end of the heim to do it.
With regards to the bushing end that goes into the differential, I scored some swivel type machined bushings for that,
Installed on the diff end
