What's your opinion on this over the factory brembos?
http://shop.kohrmotorsports.com/14-FRONT-BRAKE-KIT-S197-MUSTANG-FORD-GT-BREMBO-K-2300-GTS197.htm
I like the radial mount. Way easier removing the caliper and swapping rotors.
radial mount you just remove two nuts (sometimes bolts) that are on the top of the caliper, and the caliper slides off the studs built into the radial mount, versus pulling two bolts from behind the caliper on direct mounts. Most racing calipers are this way, and its certainly easier to a degree.
