Master cylinder code - bleed system ?
31
13
Spanish Fort, AL
Following up on ABS module thread from yesterday. So I used my scanner and read codes. It showed a master cylinder low/ pressure sensor. Sure enough it was low - I guess I had ran low on fluid when bleeding brakes and hadn’t noticed. Feel pretty dumb as I have bled brakes on this car a couple dozen times.
I filled to normal level but code won’t clear. Should I bleed master cylinder and then system?
31
13
Spanish Fort, AL
As a follow up, the car seems fine but even with the stock ABS (not Boss race) module, I have all kinds of codes. I've reset and keep getting a C1A99 brake pressure sensor code?
