- 335
- 1
cloud9 said:Well Obi Wan, I suggest you head North in late September so you can teach meadam81 said:Oh young padawan....much to learn you have..... ;D
You know I would if I could........
On #2 I don't think so with a tire suited to a 10.5" wide rim (285-315). The 18 x 9.5 35mm offset with a 285 on it sits about 1/2" from the strut. Rough calculations tell me that you're moving the center line out 1/2" (10.5 vs 9.5), but you're wider by 1/2" on either side which offsets that. Then you are tucking it back in 1/2" (47mm vs 35mm offset) so I think that would put a 285 1/2" closer to the strut (right up to it) if I'm ciphering correctly. Of course my brother Jeffro and I done gradyeated from the 3rd grade so you better double check my math.darreng505 said:Looks great. Couple questions.
1) What is the inner barrel diameter for this wheel?
2) Will these fit in the front without the cortex offset strut?
Hey nice pics of the CO Boss at RAopsdan said:
cloud9 said:Ahh but a 295 R6 trumps a 305 Nitto or Toyo or even a Conti endurance slick
LOL where can I get those???? ;Dsteveespo said:Yes but not a Pirelli Grand Am GT slick!!
Not surprised. I tested 18x10's and there was only about 15mm clearance to the strut. That was a +35 offset, so it was as far out as possible. Knew there had to be a catch. Thanks for finding out!wwilde001 said:I spoke with Filip Trojanek at Cortex. He said that this wheel will not fit in the front unless you have their offset struts. If someone finds out that this isn't the case, please post the specifics.
pufferfish said:Not surprised. I tested 18x10's and there was only about 15mm clearance to the strut. That was a +35 offset, so it was as far out as possible. Knew there had to be a catch. Thanks for finding out!
There are a number of guys running 18 x 10s, you just need the correct offset. JScheier is running one from Vorshlag I believe and Dean#4A1 is running 18 x 10s as well.darreng505 said:So 18x10's DO fit in the front without any issue? I was curious about that as well.
cloud9 said:There are a number of guys running 18 x 10s, you just need the correct offset. JScheier is running one from Vorshlag I believe and Dean#4A1 is running 18 x 10s as well.
