NEW - FP 2018 COBRA JET 5.2L TITANIUM VALVE TRAIN KIT
Ford Performance 2018 COBRA JET 5.2L TITANIUM VALVE TRAIN KIT
M-6505-CJ52
Retail $3,100.00
As used in the 2018 Cobra Jet Race Engine
Kit includes:
(32) 38.3mm Titanium intake valves 36% lighter than stock
(32) 32.5mm Titanium exhaust valves 29% lighter than stock
(32) Lash caps (to reduce wear on valve stem tips)
(32) modified 5.2L roller followers (for use with lash caps)
(32) PAC TVS-2340 valve springs - 80lbs closed and 215lbs open
7 degree valve locks
Spring retainers
Valve stem seals
Ford Performance designed and engineered to 9,000 rpm stability
Very similar to the FP350S Valve train kit which retails for $1,900
FP notes - Titanium valve spring retainers require routine replacement, normally after after each race season
Stock GT350 valve sizes - 38.3mm intake valve and 32.5mm exhaust valve
