Questions About Tow Rings/Hooks for Track Days
Boss Lady
Where do you mount the front and rear tow rings on the BOSS? I've seen some pictures of the front mounted on a GT500 and it required cutting the front fascia. Is it the same for the BOSS? Which ones do you recommend for ease of installation.
The HPDE we attend doesn't make it a requirement to run, but highly recommends you install them on your vehicle.
I really, really want to do this but hate to cut a hole in the bumper cover. I understand it is not easy to install but boy would it make life easy. the setup should be the same for the Boss as any 10,11,12, V6, 5.0 or Shelby. They attach to the front bumper, inside metal part that is. I am not certain but I think it can be bolted on or
welded.
While I have not priced them I think they are offered by Ford Racing.
908ssp said:
Mine is built into the splitter...like the Zonda R. :eek: ;D ::)
And it's the same color as the Zonda... ;D Yea how did you install them?
Actually if you just snug down the bolts, they don't move at all even at high speed. You have to pull up with some effort to move them. I did put some vinyl tape between the rear one and the license plate so they didn't rattle together.
3,875
1,529
JeffIsHereToo said:
This makes no sense to me. Let me know how this works out for you. I suspect you will see your splitter being dragged by a tow truck.
You must not know 908's skills, those are probably CNC machined titanium straps embedded in the carbon fiber passing all the way back and attaching directly to the frame. The man does some very nice fabrications.
Yea you might want to surf some of 908s posts. You'll see he can make anything. Probably could put MacGyver to shame. ;)
1,255
GA
Cool, thanks. I will have to look around for a local shop to install them.
The frame? There's NOTHING down there, no frame, to attach to with the strength needed for a tow hook. It's up behind the bumper. ???
175
Goes all the back to the K member plus that top view doesn't show the top side bars that go to the bumper. All that stuff is much lighter than it looks from below as it is all machined out on the top. I hope I never have to use them.
With the belly pans in place you can't even see it anymore.
1,465
385
Nice work there!
Has anyone installed the Rehagen Racing hooks? And when I mean installed, have you yourself done the cutting to the bumper cover? I'm planning on installing mine myself when they arrive and any lessons learned would be good to know in advance! I'm currently planning on measuring a million times and cutting once. :eek:
http://rehagenracingproducts.com/product.sc?productId=1861&categoryId=-1
Fat Boss said:
Nice work there!
That's what I have Andy. Unfortunately there were no instructions and I had my body shop install them since they had it for the Tiger hood at the time anyway. They basically welded the brackets to the front and rear bumpers as far as I know. I think they had to fab a bracket for the rear one.
drano38
Wayne
1,130
318
Got my hooks from Multimatic last week (they FedEx one-day them) and had them installed yesterday.
Now when I go 4-wheeling into the grass, they'll have a place to hook up the tow rope.:eek:
And if I can mount the winch higher on my trailer, I can use the hook to tow the car up on.
