CoolTechLLC said:http://www.saferacer.com/schroth-profi-ii-hans-6pt-camlock-harness.html?productid=2152
I looked at a set of these belts this weekend. VERY nice set-up!
It is by far the best belt system I have used, the thin hip belts are the key. They really get into your hips, and the pulls and releases are very good.
pufferfish said:i have seen one harness manufacturer (can't remember which) that provides a mechanism to allow the inside shoulder strap of the harness to release or extend in a rollover, so your body can collapse and not have your spine crushed by your head.
until i work up the nerve to install a 4pt rollbar, i will stick with my CG lock, which is a fantastic little piece of gadgetry that has been used in 4 cars now.
The single side with the snap is to prevent submarining, I doubt it would help in a roll over. Fixed back seats in general should not be used without at least a rollbar, because in theory oem seats will snap and allow you to lean back in a rollover before your head is squashed. I'm not sure I really believe that oem seats will do that, as I have never seen it happen in a roll at the track. I use a CG Lock in non-caged cars and recommend it.
