I was installing a Mishimoto oil cooler kit over the weekend and I'm fairly certain their instructions are wrong.
This is how the sandwich plate flows, correct?
This is how they say to attach the two oil lines to the sandwich plate...
Following their instructions would make oil flow in the cooler from top to bottom but you want the opposite, right? Should be from bottom to top so air doesn't get trapped, right?
Not a big deal, I can just swap the lines at the sandwich plate but I find it hard to believe a company as big as them would make this kind of mistake....hence the sanity check.
Thanks in advance!
Thanks in advance!
