I’m in the process of installing a pair of new FRPP hubs with ARP studs. Right side went on without a hitch. I hang tightened with a standard 1/2” socket wrench and send them home to 249.5 lb. ft. with my digital torque wrench. No issues there.
The left side was the complete opposite. I was diligent in cleaning the threads after removing the original hub. This time around, the nut could barely do a few turns before becoming very difficult to turn. By the time the spindle was flush with the end of the nut, it was taking over 150 lb. ft. to even move.
I was paranoid about crossthreading the spindle, so I backed the nut off and checked the threads. The spindle threads look fine. I tried the old nut for good measure. Went about two turns, met a little resistance, but freed up. Again, I could install this with a standard socket wrench to snug.
So I ordered up a pack of four nuts from the local Ford dealer for pickup tomorrow. In the meantime, I tried the new nut again. It went farther but again met resistance eventually.
I backed off once again and tried a drop or two of oil on the threads. This time it went almost to snug by hand.
It appears as though the red compound these. It’s is causing a lot of resistance. So much so that the nut and spindle were getting warm to the touch when tightening. Is this a common occurrence? Did I just draw a short straw with regards to tolerances?
I’m hoping a new nut is the ticket here because even getting these tightened to halfway forced me to break out the 24” ratchet. Even that had a bit of a hard time.
