None at all. You just get the airbag light. I was told it only disables the airbags on the side where youndisconnect the seat. i.e. if you disconnect the driver seat, the passenger side airbags are still functional.Mad302 said:Are there any adverse effects from your setup Gary. Will the car go into limp mode?
You'll need to move the under seat wiring harnesses over and get a couple of Ford airbag delete connectors (modded) to do the job. Bonus points for pulling the passenger seat sensor and the sensor Module out of the passenger seat. All of it can be put under the seat, or quasi re-installed into the bottom of the replacement seats if you want to prevent all the codes.
I have a YT link that shows the process if interested.
