BLAZN BOSS
Nope, you want the force of the lift from the front to plant the rear, soft setting will let the car use up the suspension and not get the tires the work they need. The best would be 5 on the RR and 4 on the LR and 1 on the fronts.seca954 said:PTRocks said:RoushF150 said:I was at Cayuga in Ontario. I could launch the car with no wheel spin but it would just bog. Any kind of spin resulted in bad wheel hop. I had shocks set at 1 all around and 2 or 3 in the rear might have reduced the hop. Going to change LCA's and try again. Car is just at beak-in point and still has more power to come. This is my 2nd 13 BOSS and has not caught up in power to the other one yet.
Someone please correct me if I'm wrong here. I would think that setting the rears to 5 would give a better launch because the tires would be pushed harder into the pavement. Setting the fronts at 1 would allow the front to lift more, transferring weight to the back as well.
I theory, you should have all the shock set at 1. You want the rear shocks to be soft so the car will squat it's weight down. Ideally the front shock would allow the front of the car to rise quick and slowly come down.
