Hi all,
I am new to the form. Bought my 2011 GT in 2016 as a salvage title car with 1800KM (~1100miles). It sat for 6 years. It is an early 2010 build and was slavaged in Aug 2010 for hydro-locked engine that resulted in 3 holes in the block. Started building car in late 2017 and got it on the road in 2018. Built as a track car, but waiting for a track near me to finally open (next summer). Only has 3000 miles on it now.
I have raced for 20+ years. I have raced karts, sports cars, Formula 2000, stock cars both road race and oval. Some lower pro level stuff. So pretty experienced. Have my kids in karting now and have briggs for myself (can you say momentum!)
This is my build for the track
Front Suspension
MCS TT1 single adjustable coilovers
550#/in springs
Whiteline 33mm adjustable sway bar and endlinks
Vorshlag Camber Plates
Rear Suspension
250#/in springs
Whiteline 27mm adjustable sway bar and end link
Whiteline Watts Link
Whiteline Rear adjustable LCA with C-Max Bushings
Whiteline rear LCA relocation brackets
Front Brakes
OEM Brembo 14" with G-LOC R12 pads
Vorshlag rotor baking plates w/ 3" duct (need to add ducting and intake)
Rear Brakes
OEM GT with G-LOC R10 pads
Engine
Forged Rods and Pistons (stock compression)
Bored 0.010” Over
Comp Cams Stage 3 Cams, Boss 302 Valves, upgraded springs
Phase limiters
Custom hand ported heads
Ford Racing 47lb fuel Injectors
Cobra Jet intake Manifold
Ford Performance Twin 65mm Cobra Jet Throttle Body
Ford Performance 5.0L Cobra Jet cold air kit
Stainless work 1-7/8in long tube headers with off road pipe. No Cats
3” exhaust
ARP head studs
Billet cam gears
Billet oil pump gears
Cooling mod
Mishimoto Rad
Poly engine mounts
Boss oil cooler
Dyno Tuned (on a very stingy Mustang Dyno - 412whp vs stock 2011 coyote of 334whp - Approx 510hp crank)
Redline set at 7800rpm
Stock MT82
Whiteline Positive shift kit
Act Clutch and Macleod flywheel
Differential
OEM 3.73 Gears and LSD
Wheels and Tires
Street: Apex EC-7 18x9.5 w/ Indy 500 275/40R18
Track: TBD
Exterior:
Stock
Interior:
Stock
Future plans
Front Suspension
Poly lower control arm bushings
Steering Rack - Does a 2012+ GT rack work with poly bushings or do I need to Boss 302S rack?
Differential
Upgrade LSD?
Oil Cooler required?
Taller gears?
Wheels and Tires
Undecided - See post in Wheel and Tire section
Exterior
Driving light delete
Cooling vents in hood or aftermarket hood
Front Splitter
Rear Wing
Interior
Gut
Full Cage
5 point harnesses
Racing Seats
Steering Wheel
Thoughts on my build and future plans?
Front Suspension
550#/in springs
Rear Suspension
250#/in springs
Front Brakes
Rear Brakes
Engine
Bored 0.010” Over
Phase limiters
3” exhaust
ARP head studs
Billet cam gears
Cooling mod
Mishimoto Rad
Poly engine mounts
Boss oil cooler
Stock MT82
Differential
Wheels and Tires
Track: TBD
Exterior:
Stock
Interior:
Stock
Future plans
Front Suspension
Differential
Upgrade LSD?
Taller gears?
Wheels and Tires
Exterior
Front Splitter
Rear Wing
Interior
Gut
Full Cage
5 point harnesses
Racing Seats
Steering Wheel
