Sesshomurai
Guest
What's the difference between a rear "trailing arm" and rear "control arm"? Are they the same thing? What do they do exactly?
I think I understand what the control arm is for.
darreng505 said:What's the difference between a rear "trailing arm" and rear "control arm"? Are they the same thing? What do they do exactly?
thats the hard way to do it. with wheel on from behind remove retaining clip, pull down on cable and pull out of the slot. this will free up the end that pulls and slips right out. install in reverse order.TMSBOSS said:Removing the E Brake cable is easy.
Remove the wheel, retract the cable housing, pull the cablethrough the slot in the cable housing bracket, turn and remove the cable end from brake.
