Has anyone noticed uneven pad wear (one side vs. other of the same pad) on the front brakes ? I saw this for the first time on the Boss at Watkins Glen this past Mon/Tues. When I went to checxk the pads before I went out the side I was looking at had enough pad left for at least 1 more run. Come to find that the other side (bottom) you can't see easily was down to the backing plate.
PS: This happened on both sides, left and right, inside pads. Big thumbs up for the Coleman cryo treated rotors, evem though I was on the backing plate the rotors showed absolutely no evidence of it at all. Obviously the rotor steel is much harder than the backing plate itself.
