Watts linkWatts and torque arm
Discussion in 'Boss 302 and S197 Technical Forum' started by Gt500jerry, Aug 23, 2018.
  1. Gt500jerry
    Gt500jerry TMO Intermediate
    24
    11
    Dec 17, 2017
    Riverside ca
    Thinking about pulling the trigger on cortex watts link and torque arm. I only track it 3 to 4 times a year just like the stable feeling the provide. Just looking for any advice on these.
  2. VoodooBoss
    VoodooBoss Rick Moderator
    20,439
    2,826
    Nov 30, 2010
    I really liked the CorteX watts link on my Boss 302. Not sure if I was any faster with it but I liked how it behaved over curbs on track and bumps on the street.
    Gt500jerry likes this.
  3. Wingrider
    Wingrider '11 GT500, 99% Track Car. Lots of mods & I coach
    313
    91
    Aug 6, 2013
    NorCal- Halfway between Laguna and Sonoma.
    +1 on the CorteX watts and Torque Arm. Flattens out the car and really plants the car.
    TymeSlayer and Gt500jerry like this.
  4. Gt500jerry
    24
    11
    Dec 17, 2017
    Riverside ca
    Did you install yourself? If not about what was the cost?
  5. Wingrider
    313
    91
    Aug 6, 2013
    I live in the bay area and had CorteX install their full system front and rear plus some other things like the FR 302r ABS so I'm sorry I don't have a figure on the labor for that section.
  6. Pitt302
    Pitt302 TMO Advanced
    114
    11
    May 30, 2013
    Pitt Meadows B.C. Canada
    Did the install of Cortex Watts link, Torque Arm, LCA's,in my garage. You need to drill two holes in Diff housing,other wise bolts right in. I also went with one piece Drive Shaft at the same time.
  7. Gt500jerry
    24
    11
    Dec 17, 2017
    Riverside ca
    Im not a great mechanic. Most shops want around 800 to 1000 to do the install. I really don't want to spend that but I don't want to mess it up.
  8. ArizonaBOSS
    ArizonaBOSS Because racecar. Moderator
    8,190
    1,817
    Dec 6, 2010
    The watts is a bolt-in affair. If you have a capable friend maybe you can get them to install it for beer and pizza...
    What I really like about the CorteX watts is the ease of adjustment and also each position in the roll center adjustment can be felt as an actionable change to the car's on-throttle steering and power-down characteristics.
    VoodooBoss and Gt500jerry like this.
  9. Gt500jerry
    24
    11
    Dec 17, 2017
    Riverside ca
    Thanks man. I do have some handy friends.
  10. ArizonaBOSS
    8,190
    1,817
    Dec 6, 2010
    Here are the installation sheets for the Watts and Torque Arm, so you can see what you are getting in to. I haven't installed a torque arm before, but other than the drilling the ears of the differential housing it looks very simple; and the way they have you set everything else up first makes it seem like that drilling activity will be fairly foolproof (but will take some time to get through all the material).
  11. Gt500jerry
    24
    11
    Dec 17, 2017
    Riverside ca
    Thank you
    ArizonaBOSS likes this.
  12. Coz
    Coz TMO Race
    344
    261
    Mar 4, 2018
    Philly Metro Area
    With the Torque Arm, what consideration must be made if using a one-piece driveshaft?
    I've heard that the pinion angle is more important with the 1pc. With a lowered car, I think the only way to adjust it with a TA is to cut down the mounts on the TA that attach to the rear diff housing.
  13. Pitt302
    114
    11
    May 30, 2013
    Cortex preset my LCA length for Torque Arm/ T spring, everything bolted up, no adjustment for Pinion angle, was told Torque Arm set this right. I suppose you could adjust by shimming the ears where it bolts to Diff. The stock UCA/third link is a little difficult to remove , you need a very large wrench with cheater bar to loosen the bolt under the rear seat.
    Wingrider and Gt500jerry like this.
  14. Fabman
    Fabman Project: "Frankenstang"
    2,470
    1,415
    Jan 31, 2016
    It's not that hard really, especially if it's done on a lift. Just follow the directions and you are good to go. Pinion angle is pre set in the geometry of the torque arm. Again, follow the directions are you will be fine.
  15. Wingrider
    313
    91
    Aug 6, 2013
    CorteX did a great job setting up mine because a year or so later when I had the 2pc removed and Driveshaft Shop CF driveshaft put on- the angles were perfect and the spacing was perfect. Bolted right up and has been great.
  16. Wingrider
    313
    91
    Aug 6, 2013
    I'd sure like to learn more about how to explore those watts adjustments, but I'm fortunate enough to be able to have CorteX test/drive the car around Sonoma and I just assume I should leave it how they adjust it.
  17. Fabman
    2,470
    1,415
    Jan 31, 2016
    Lower the pivot to tighten the car up, raise it to loosen it up. That's it in a nutshell.
    Of course there's more to it, but that requires a bigger nutshell.
  18. ArizonaBOSS
    8,190
    1,817
    Dec 6, 2010
    Agreed with Fabman with the very important aspect that in the lower settings on the watts, the car was more responsive to throttle steering. Depending on your driving style you could get the car pointed towards the exit and unwind the wheel earlier than you thought, provided you got on the throttle early enough and aggressive enough. Somewhat counter-intuitive but it can work very well depending on driving style. Lower settings could actually be very useful for shorter tracks with tighter turns.
    Wingrider likes this.
  19. Wingrider
    313
    91
    Aug 6, 2013
    These have been informative, thank you. Wait- So if I want less oversteer moving up one hole could improve that? I'm reading a contradiction in the two opinions. I must be misreading these... Oh wait- got it.
  20. Grant 302
    Grant 302 OPM Spent: $665,833 Moderator
    6,797
    1,722
    Nov 23, 2011
    In the OC
    Down for less oversteer and more grip in the rear.
Share This Page
