Got new DD shoes for the Boss.
Bridgestone Potenza RE760 Sport in 275/40/18 from Discount Tire Direct.
I'll powder-coat my silver Enkei's to satin black, and make them street wheels. Stockers will hibernate in the pony coral attic.
Out for a ride yesterday with my daughter and the engine light came. Took it to the dealer today, and it was a mis-fire in cylinder 3. All parts checked out good. They said they undated the computer and should be fine. Drove it tonight again with my daughter and all seems good.
Black Boss said:
Got the car ready for Mid Ohio on Monday. Changed the Front Pads, swapped out the Rear Rotors, replaced the Tranny Fluid, Bled the brakes and installed the Airaid CAI:
Nick who made the shield over the filter?
Checked my Peterson breather can to find no oil in the can but a hint of it on the foam insert. Have run only about 500 miles since I installed it. Checked all the other fluids as well as I prepare the car for my first track day on June 7th. Anyone out there have a good base checklist they use for track day?
Grant 302 said:
Dropped off her slicks at storage:
Gave her a bath:
I'm gonna try that way on Sun. Before I installed the
harness bar I put all 4 straight across and wedge chocks
under them, visibility wasn't 100% but it was ok.
Now I put 2 back there and 2 in the trunk.I Gotta get a truck!
I have almost 10,000 miles on mine and there's barely any oil in it.
Cool. Post pics! And just to clarify, there all 305 Pirelli DH scrubs, on the bottom layer are a 645 and 680, with a 680 on top and a 645 behind the passenger seat.
I do believe thats because there is no vaccumm going to the peterson can. All others have the catch can cut into the vaccumm line.
Thats my theroy.
Thats my theroy.
Your theory is correct as vacuum is produced behind the throttle body, (throttle plate), and in the intake side of the engine. High vacuum is found at idle and peeks or spikes during the moment you come off throttle after a WOT event.
The PCV valve is just a check ball that creates a one way valve (so to speak), which is located on the valve and coil covers on the passenger side of engine. The system works by drawing in air from the drivers side intake tube, thought that side valve and coil covers, through the crankcase, through the PCV valve and in to the intake manifold fitting located on the passenger side behind the throttle body.
This is also why one will not find oil in a catch can located on the driver side. Any oil that would accumulate in the Peterson CVC, (crankcase ventilation can), or a driver side installed catch can, would be "pushed" there from excessive engine crankcase pressure. Not a good thing as a cause of this might be excessive cylinder/piston blow-by from worn rings, etc.
Hope this helps,
Dave
302 Hi Pro.
Took the driver's front caliper off and replaced the boots and seals. Only one boot actually came out in one piece, so I guess I got my money's worth out of them.
The thread on how to do it, and parts from KNS Brakes made it a pretty straight forward project.
Fixed that pesky mess on the stripe on the passenger side in front of the rear wheel. I need more practice but it looks better that the original which somehow got grit beneath it.
Before
After
Before
After
It looks like you replaced the factory stripe.
The stripes gaps look different at where they end on the car.
Never understood why the factory stripes end and start where they do, leaving that 1/4" or so.
O-well.....Nice job!! ;)
Before
After
Nice work. But I'm wondering why you didn't make this a repair under warranty.
