Wheel rates might be about 255 vs 330 or so. Sometimes I get a little clunk when I go from forward to reverse and vice-versa once I get rolling. I couldn't think of a way to prevent it with heim joints on both ends. I assumed mine are just hitting the limit of rotation when it does that. I'll look closer next time I'm under the car.
Well. My death rattle is still there. Only thing I can think of now is shock mount bearings. I have checked them, they don't seem loose.
Sent from my SM-J700T using Tapatalk
You mean contact with the shock body and upper coilover mount?
STANCE!
Center pivot on the watts was loose, pulled it all apart, cleaned it, re-greased it, replaced the rod ends with good ones, Put it all back together and torqued it all down to spec. Got the pivot to sit straight up and down with equal arm length. Wheels are centered. That's really is a pain.
Re installed my 22mm rear bar....hoping this will help hook the front back up without some detrimental side effects.
Just replaced my front left side sway bar end link with the Watson Racing adjustable one. Ordered the Moog non-adjustable for the right.
Smart. You only need one side to be adjustable!
Newb question(s)...why have an adjustable, and what are the tuning fundamentals of this part? Also, is there a part #? Not seeing it on Watson's site.
