Good luck and hopefully you get over 2.5 degrees of negative camber up front? Post pics and videos (if you can), as we all want to run that Legendary Track someday?
Had an eventful weekend at Laguna Seca.
Managed to easily get -2.7 degrees of camber with Vorshlag CC plates and Steeda Boss Springs, could have gotten a little more but -2.7 was actually already too much considering the wet track conditions and stiffer springs and dampers. Once most of the track dried (turn 3 remained a river and the braking zone into 2 never fully dried) my tires definitely appreciated having some more negative camber and wore much more evenly.
Was still able to have some fun and chase down some fast cars (AMG GT, F80 M3, track prepped C5Z). Was very close to keeping pace with an Exige, but couldn't match a K20 swapped "spec" Miata that was absolutely flying!
Then unfortunately I found a coolant leak from the oil cooler right at the junction of the hard line and the cooler, which sounds like an issue a handful of you have had. Spent Sunday trying to patch the crack well enough with epoxy to get the car home without having to drain the whole system and managed to get the car home over 8 hours of snow detoured driving.
Tried to bring my car back from the dead. It had been sitting for years, couldn't pass smog (long tubes) and life got busy, so it sat. Had a lot of time and thinking put into it so I wanted to stay with the platform despite it's inferiority to newer cars.
With tons of help from a friend, we got it smogged and prepped and finally out to a trackday last weekend.
Recap on the car:
Cortex offset JRi DA coilovers
35mm sway bar up front, the skinny v6 bar in the back
Cortex watts link and LCAs and brackets
BMR spherical UCA
Sparco evo2 seat and Watson roll bar
Carbotech XP24s and Castrol SRF
Cooltech oil cooler (Setrab cooler and Greddy remote mounted thermostatic oil filter block)
Fluidyne radiator
My to do list was vast for a guy like me:
Prothane front LCA bushings
Ford racing M-3200-EPAS steering rack
Maximum Motorsports k member
Remove long tubes for stock setup
Remove Airaid CAI
Remove Peterson crankcase breather
Square Forgestar CF5 18x12s and 305/35/18 NT01s
Reinstalled Stoptech ST60s/380mm front brakes
Moroso aluminum oil pan
Reconfigure oil cooler to use a thermostatic sandwich plate (rather than the remote mounted Grex/Greddy unit in the cooltech kit--much easier to now get to oil filter)
Some photos of the progress
bd13df194c7121c589f46f4e7c748a70.jpgd47ffbe3a03135468952af89a3817aab.jpg5161e251db97b76b24f4cf21081a0fe1.jpg0b36df9bc4cbaed75f2c28e6f57ebf8a.jpgd49f541295612f362e235be10d1ef2f0.jpgb3a16a6d651c5f1b39ec73ff9f98ea56.jpg054a2d33c720f11b53b1b9e2971e7d36.jpgf6e613222ee2f5b971f9d5f43b4aa7d2.jpg3097e36d890495d17e9ef1dd9995e90e.jpg
Oprah called and told me congratulations on my weight reduction!! Went from Fatstang to Skinnystang with all my ideas to reduce weight, but , like many plans I may have pulled a Tymeslayer and done a bit too much. Now I weigh about 70-100 lbs too little and it is time to go back and put in some strategic weight. Trying not to laugh as I guess I over did things, but after reading numerous posts from others, I feel I am in good company in overdoing it, ha! Essentially my ass is light , so guess I am going to have to get the lead back into my rear end, instead of getting the lead out?
Welcome to TMO. Not sure what was in the box but it probably wasn't related to the exhaust setup.
