Looking for a sanity check from those with more track experience-
I have a base Dark Horse (non-HP) running the factory Brembo brakes and OEM brake pads.
Recently had the car at Ford service for oil change & safety inspection and they measured my pads at approximately 6 mm front and rear.
Shortly after that, I ran a track day at The Ridge. I completed about 4 x 20-minute sessions and was running what I'd consider a slower/intermediate pace, with lap times around 2:00 (faster groups were running about 1:50). Brakes felt fine.
Based on everything I'd read online, I expected to come home needing new pads. However, I recently got the car on a lift and measured the pads myself. I checked both the inner and outer pads and didn't see any significant wear. I'm still measuring approximately 6 mm front and rear.
- Does this level of pad wear sound reasonable for a Dark Horse on OEM pads after a track day?
- Am I likely just not using the brakes as hard as I think I am?
