BOSSAZ said:Here's a pop quiz for the "Window Sticker Experts".
Window stickers when available from the Ford Webview link initially show "FLR-00XXXX" for (Flat Rock) in the top left corner but the xxxx number changes every few days?
Could the associated FLR number eventually be the actual sequential Boss number?
These window stickers initially include the "Blend Number" at the top center and again at the lower right corner.
Following the confirmed "Build" for the vehicle the window sticker changes once more...the "FLR-xxxx" number changes to a new, much lower number from four to two digits, the "Blend Number" is absent, the complete VIN is printed top center with "Mustang" to the right and the numbers below the "Item" box change?
First one with the correct answer wins the prize!!! (NO GUESSING)
The Blend number disappears when the window sticker is reissued, likely after the car is built. The older versions of the window sticker used to say "4-rebill" near the upper left corner. The number after "FLR-" is a sequential number that appears to be related to the batch of stickers as they are created. Stickers that are rebilled before the car gets built still say "rebill" on them. The original sticker is labelled as "9-normal".
The number after 'FLR' drops lower because the revised batches are much smaller.
I don't know all the numbers in the window below "ITEM", but here is what I know:
E.G. "CB041 N RA Z 300 000006 02 04 12"
CB041 - date code for creation of the invoice/window sticker : C = 2012, B = Feb, 04 = 4th, 1 = 1 (always there, never changes)
N = Normal, (R = rebill in this location)
RA = ??
Z = ??
300 = Price level - this is revised once or twice during the model year
000006 = invoice sequence number, also found after "FLR-" in upper left corner
02 04 12 = date of invoice -> Feb 4th 2012
KATO64 - Your original window sticker had a couple of errors. If you still have it you will see it refers to the following standard feature: "UNIQUE HOOD STRIPE AND REVERSE "C" SIDE STRIPE". It also lists the mirrors as: "HEATED SIDE MIRROR BLACK"
